New Batterys to try out
andyquirot
Been liked: 33 times
Post by andyquirot »
Hi All
I have got some new lipo batterysto try out
Minimum Capacity: 16000mAh
Configuration: 6S2P / 22.2V / 6Cell
Constant Discharge: 10C
Peak Discharge (10sec): 20C
Pack Weight: 1920g
Pack Size: 173 x 74 x 68mm
Got 2 of these for 32Ah
Regards Andy Quirot Jersey
New Battery Half the size???
dennypatterson
Been liked: 1 time
Re: New Batterys to try out
Post by dennypatterson »
:roll: :roll: how much????? denny.pounds or that other money...
andyquirot
Hobbyking under lipos
US $119.86 Each
20Ah also avabile
Minimum Capacity: 20000mAh
Configuration: 6S1P / 22.2V / 6Cell
Pack Weight: 2405g
Pack Size: 200 x 90 x 60mm
$145.92 Each
Has liked: 161 times
Been liked: 830 times
Andy,
Keep us posted on how those work. The price wasn't too bad - I paid about $90 USD each for 22Ahr batteries for my Panther. They weigh about 20lbs together (2x). That weight didn't bother the Panther, but is too heavy for smaller tanks. A lighter solution w similar power would be great - esp for smaller tanks and vehicles.
You could always add a third pack for accessory power if two drain too fast.
Has liked: 1484 times
Been liked: 1693 times
It will be very interesting to see how you get on with these, as they're 6 x 3.7 volt cells rather than the 8 x 3.2 volt cells of the LiFePO4 batteries which have been discussed here before.
Overall the voltage and capacity seem to stack up nicely, so it's likely that any difference in performance will be down to the internal cell technology.
It will be interesting to see if the nominally lower maximum voltage will have any noticeable effect.
