Uwe's PAK
- Been liked: 45 times
Uwe's PAK
Hello from Cologne ,
I'm really looking forward for the October events so I had a start on PAK
The "fit & function" has been finished yesterday and everything is working smoothly now
For the Guiness target it should be OK like it is now
The only Mods I've done are on the diskwheels and a "recoil-upgrade"..
One point I'm struggeling with are the rivets hundrets of 2,0 mm holes but 1,6mm rivets
Has anybody the round-head dimension of the original rivets at the PAK ???
That Info would be much appreciated to figure out some potential alternatives.
So tomorrow back to the FLAK Boogies to have them same level ready for October
Cheers ,
Uwe
Cheers ,
Uwe
1:16 Models: Kingtiger
1:10 Models: Flak-Panther Coelian, Panther A , S.WS with 3,7cm Flak 37
1:6 Armortek Models: Flak 36 2006, Kingtiger 2013, Sd.Kfz.7 2014, PAK 43/41 2015, SdKfz 251 2016, FAMO 2018
1:6 other Models: Opel Blitz , Kübelwagen , Zündapp KS750 etc...
- Been liked: 53 times
Re: Uwe's PAK
Your Pak is looking good Uwe,
What size are these Castellated Nuts on your disk wheels!
They look smaller than M3 size!
Did you buy them somewhere! or did you make them yourself?
Not sure about the size of the rivets to use on the Pak yet!
Ian
Ian
Re: Uwe's PAK
Looks great I will be ordering my Pak in Sept. Approx. how long is it with the barrel in two parts (I assume it ca be reduced for storage) Reason I want to but a Really Useful Plastic storage box to store the gun (prob. with wheels removed).
Thanks Doug
Thanks Doug
Re: Uwe's PAK
Hello Ian and Doug ,
hope I can answer your questions as follows:
The Castle-Nuts M3 with SW4,5mm I got a long time ago from Martin Diessel. They were "selfmade" CNC'd and not available in any regular shop. I need myself more of them for several apps on my models so I've contacted Martin allready for that.
The Hex Bolts are from Knupfer Germany, M3 x 20mm SW 4,0mm, shortened to 17,0 mm lenght.
Doug,
the PAK is with disassembled front part of the barrel 1090 mm in lenght, and roughly 460 mm wide including the wheels and hub-caps, hight at about 340 mm. You can safe another 100 mm in lenght by turning the tow-bar inbound for transport
So the min inner DIM of a Box for transport should not be less than 460 (w) x 1000 (L) x 350 mm (H)
Hope that helps a bit,
cheers from Cologne,
Uwe
Doug,
Uwe
Re: Uwe's PAK
Hi Uwe,
That was really useful;, many thanks for taking the time to reply in detail.
All the best
Doug
All the best
Doug
Re: Uwe's PAK
Hi Uwe,
Thanks for the info on the castellated-Nuts etc.
Looking forward to seeing your Pak at Armortek big weekend in Oct.
Cheers from Glasgow
Ian
Cheers from Glasgow
Ian
Re: Uwe's PAK
Hi Uwe,
1000mm seems to larger than the Really Useful Storage boxes I can find on Amazon. Before I go build a custom box approx what is the length trail to shield? I was thinking of drilling a hole in large Really Useful Storage box and point the barrel out. Hey, it's worth go!
Man thanks Doug
Man thanks Doug
Re: Uwe's PAK
Hi Doug,
I'm pretty busy on FLAK again so it took a while
The options you have to reduce the BOX lenght are :
1.) Lenght to the front edge of the wheels = 740 mm :
Means you have to slot the Box and the cradle and barrel are looking out of the Box and are unprotected !
2.) Lenght to the front end of the cradle = 860 mm :
This would give the option to work with the barrel recoil dis-engaged and the Barrel seperate stored in the Box. The PAK would be fully protected in the Box.
Suitable Boxes are pretty hard to find on regular sources, have a try on Industrie used ones..
Here in Germany we have e.g. Auer .
I'll have a look next week for it, since I have the same task to be solved, and not only for the PAK .
Uwe
Uwe
- Has liked: 8 times
- Been liked: 4 times
Re: Uwe's PAK
Hi Doug,
Another way to go is in 3 parts, to remove the 4 bolts holding the trail arms to the main frame 55cm, barrel and breech block 63cm ,front barrel and muzzle brake 50cm.
for boxes go to http://www.reallyusefulproducts.co.uk web site is in 6 languages , I Ordered from them and got my boxes in 3 days, hope this is some use to you.
Regards Walter.
Regards Walter.
Re: Uwe's PAK
Hi Walter,
That a good idea and sounds much easier to store. Which boxes did you buy? I was thinking of using Amazon UK
Many thanks
Doug
Many thanks
Doug
Re: Uwe's PAK
Hi Doug and Walter,
standing in the forest and don't see the trees anymore
Walters hint is so clear..., just since I'm lazy I'll modify just slightly the pivot-pin and secure them with a spring pin (RC car use) instead of the bolts - no tools required and pretty quick
Later today I'll post a pic of my setup,
cheers,
Uwe
cheers,
Uwe
Re: Uwe's PAK
Hi Doug,
It was the 11 Litre boxes with 15 tray inserts for holding the nuts and bolts for each model, If you check out the website and compare with Amazon prices then make your choices.
Regards Walter.
Regards Walter.
Re: Uwe's PAK
Hello folks,
a long time now ago that I've shown any progress on my builds...
My friend Paul Wills has allready complained about the lack of posts
Paul , , here are some mods I've done on my PAK e.g. with the Muzzlebreak, sight apparatus wheels etc.
On the fair in Dortmund early last year I meet a nice couple selling special treatment chemicals used for guns . The technology is called " brünieren ". What is that correct in English ???
Very interesting stuff and I'm very pleased with the results. Maybe of good use for several applications in our hobby
Hope it's of interest
Uwe
Uwe
