Question - Left Track not running smooth
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
hi all
Hope I can get some advice here
I have had the JagdPanther through a major overhaul including suspension, sprockets etc.
I took the JagdPanther for a trial rund Sunday and here's the thing.
Right track is running very smoothly
Left track is noisy (Watch video 4:35 min and Again 8:12 min and you can hear it)
I carefully installed the idler and sprocket as described in the manual but can it still be a mis allingment of the sprocket that I should look after before taking it apart and investigate
cheers
Steen
Steen Vøler
Has liked: 62 times
Re: Question - Left Track not running smooth
Problem solved - I did not set the sprocket 100% correct.
Now - this is fixed and the cat spins againg :-)
cheers
Steen
