Power on off switch
Posted: Tue Apr 07, 2015 7:56 am
by Ray Brown
G'day,
I want to be able to switch the power on/off via an external switch as opposed to the on/off system via the power supply module inside the tank which is the current set up.
Any suggestion on how to re-route the power switch so that I don't have to dig around through hatches or small holes. I was thinking of using a rotary switch.
Thanks guys.
Ray
Re: Power on off switch
Posted: Tue Apr 07, 2015 11:18 am
by Dennis Jones
Hi Ray,
I did this on my Panzer III, I just used a push button switch and extended the connections from the switch in the power supply, it involves some soldering. The switch just needs to be single way and single pole and obviously has to be non latching. Any more info let me know.
Dennis.
Posted: Tue Apr 07, 2015 7:36 pm
I've done the same as Dennis for the BARV and can confirm that it works a treat.
It's worth noting that the Power Module remains powered even when switched off, so it's worth having a nice big physical switch in the battery line somewhere, so that you can isolate the battery completely.
Posted: Wed Apr 08, 2015 1:23 am
by Ray Brown
G'day Guys,
Thanks for your responses. Are you saying I need to remove the circled switch and re-solder wires to another switch. That's the way I understand what you've written.
Picture below.
Ray
Posted: Wed Apr 08, 2015 6:20 am
You don't need to remove the switch, just solder the new one in parallel across the existing one. Then you can easily return it to "stock" condition should you need to.
Posted: Wed Apr 08, 2015 6:36 am
by Ray Brown
You mean like this picture..................
Posted: Wed Apr 08, 2015 11:49 am
by Dennis Jones
Yep just like that.
Dennis.
Posted: Wed Apr 08, 2015 11:58 am
by Ray Brown
:D :D :D :D :D :D :D :D :D
Thanks a million. Is there anything I shouldn't use or do?
Ray
Posted: Wed Apr 08, 2015 12:34 pm
by Dennis Jones
As long as the push button switch is non latching and push to make. Current is very small so doesn't need to be a big switch.
Dennis.
Posted: Wed Apr 08, 2015 7:36 pm
by Steve Stuart
Following Dennis and others inspiration I have fitted auxiliary non-latching switches to my Tanks so as to have an easy access to turning the power off by being able to use a smaller and more convenient hatch. Also I have put in an additional, remote 'Power On LED warning light' by the switch.
I have had the embarrassment of failing to turn the Tank off before the Transmitter happen more often than never :oops:
It is quite straight forward to do, I use a spare servo lead cut in two,so that a plug and socket is included to make working on the wiring system easier, as items can be then easily disengaged.
Posted: Wed Apr 08, 2015 8:40 pm
by Christoffer Ahlfors
http://www.armortek.co.uk/Forum3b/viewt ... 884#p27884U
I see your power module even has a jumper where mine only had holes. Use it for a solder free connection!
/Chris
Posted: Wed Apr 08, 2015 10:05 pm
by Steve Stuart
Thanks Chris for 'Bumping' the thread. I hope it will prove useful with its different solutions to the question. Steve
Posted: Sun Apr 12, 2015 11:12 am
by Ray Brown
thanks for the help. i've mounted the new switch at the rear.
