Hi all
Before i connect it to something does anybody know what the 3.5mm jack socket is for.
Pre amp out or the fan as i read somewhere that the fan speed is controlled by the sound board.
Many thanks
Andy Quirot
Tiger 1 Armotek Orig sound board 3.5mm jack socket??
- Been liked: 33 times
- Has liked: 1484 times
- Been liked: 1693 times
Re: Tiger 1 Armotek Orig sound board 3.5mm jack socket??
It's possible that a previous owner has modified it. All the factory wiring was done with the 1/4" blade connectors at the end of the unit.
The factory supplied fan has always been controlled by the speed of one of the driver motors, so is proportional to the speed of one of the tracks - no link to the sound.
Unless you buy one of my gadgets that is
What gadgets do you have a list/web site.
Regards AQ
Regards AQ
These are the fan control units, which link the fan operation to the engine sounds, rather than just whether the tank is moving or not:
http://www.armortek.co.uk/Forum3b/viewt ... 373#p37613
John Grima has kindly mentioned it in his recent thread on his Tiger build.
To use with something other than a Benedini board, you also need one of these:
http://www.armortek.co.uk/Forum3b/viewt ... f=4&t=4467
I tested it with an original Sherman sound unit and it seemed to work OK, so no reason why it shouldn't work with a Tiger one.
