Degreasing and painting
John M. Lyle
Been liked: 1 time
Post by John M. Lyle »
I have done a dry fit of my Armortek model, the Gun limber and 25 pdr gun. Do I have to completely dismantle the models to degrease them? Should I degrease before I apply Loctite to various parts? How do I degrease the models, do I immerse them completely in a solution or would the spray can degreasers work?
Where would I find the etching primer for Aluminum? I live over in Canada. DO I dismantle the models to paint them and then reassemble or can I just paint them as built?
Sorry for all the questions but these are my first all metal models.
John
Peter Silcock
Has liked: 60 times
Been liked: 33 times
Re: Degreasing and painting
Post by Peter Silcock »
John I think you will find that everyone has their own way of painting their models. I personally would dismantle the model to paint at least the primer coat. You probably need to visit your local auto parts store and buy a can of pre-paint or panel wipe which are applied with special wipes. Ideally its better to use a light coat of acid etch primer on the panels before a normal primer, then assemble and apply your colour coat. As I say everyone will probably do it differently.Your auto parts store should be able to point you in the right direction for the relevant primers. Good luck!
John M. Lyle
Been liked: 1 time
Thanks Peter. That helps
