Mark IV 014
Dave Chalmers
Mark IV 014
Post by Dave Chalmers »
My Mark IV has arrived, and I started the first task of checking off all of the parts last night. I'm excited to see how well others builds are progressing!
Dave
Ray Brown
Has liked: 26 times
Been liked: 103 times
Re: Mark IV 014
Post by Ray Brown »
G'day Dave. Have fun. Hope my posts help if you get stuck.
Ray
Dave Chalmers
Re: Mark IV 014
014 is progressing slowly. I reached step 14 but have disassembled most of the vehicle, to follow Ray's suggestion of finishing each sub assembly.
I'm not sure how the MG mountings fit in the male sponson, and would appreciate an idiots guide if someone has time to explain it to me.
Does anyone know when the motion kit will be available? I'd rather get it so I can figure out how it fits before I go too much further
Dave
Steve Stuart
Has liked: 264 times
Been liked: 195 times
Re: Mark IV 014
Post by Steve Stuart »
Hi Dave
I too had to stop and think about fitting the Machine Gun Ball Assembly.
You need to look at Page 31 and then take inspiration. The Brass Socket Collar EK0621 sits in the hole in the Hull, the Lewis Ball EK0623 is then kept in place by the Socket EK0622 which is on the inside and is bolted to the Hull with six bolts. The Brass part needed judicious filing as it was just a little too big.
I hope this makes sense...
Male Sponson
Male Sponson
This picture shows the external view.
Dave Chalmers
Re: Mark IV 014
Thanks Steve. Did you use the M3 x 8 hex bolts?
Are the countersunk holes on the outer sponson for the motion pack?
Dave
Steve Stuart
Re: Mark IV 014
Hi Dave
I guess the countersunk holes are for the motion pack and they will be filled in due course!
For attachment, I am using 2.5mm bolts with the nuts on the outside, the length I have not decided on, but I think I will need to file down bolts to suit the appearance in photos. The Bovington Tank is my prime model!
Has liked: 1038 times
Re: Mark IV 014
Dave hi. I've sent you a pm, when you have a moment to spare. All the best. Stephen
