Aluminum Wheels For SdKfz 250, Trailers and Pak 35/36
Mike Stannard (toyrific)
Hi Guys
At long last I have the aluminum wheels in stock, 50 pairs only of which 23 pairs are pre-ordered, I doubt these will be made again due to the problems I had in getting this first batch done and the likelihood of the company that made them may want me to increase the order to 1000 pieces which seems to be their policy once the first order is made.
These wheels were used on vehicles, trailers and the 37 mm Pak 35/36 and had two different grease caps, I have produced both types and each set of two wheels comes with both types of grease caps so you can used them on a vehicle, trailer or gun. A set consists of two rubber tires, two rims, two hubs and four grease caps (two of each) plus 10 x 4-40 x 1/2" bolts and 10 x 4-40 lock nuts to bolt the wheel rims to the hubs.
Item # WH01 Set of two tires, rims and hubs with four grease caps (2 of each) & 10 nuts and bolts. Price $80.00
Here is a list of vehicles, trailers and guns that these wheels were used on. This list may not be complete.
Trailers with two wheels.
Sd.Ah.20 Underground Cable Layer
Sd.Ah.23 Type D Battery Charger
Sd.Ah.31 Ammunition Trailer (Stug III) Towed by SdKfz 252
Sd.Ah.32 Ammunition Trailer 37 mm Flak
Sd.Ah.33 Ammunition Trailer Nebelwefer Rockets
Sd.Ah.51 20 mm Flak 30 and 38
Sd.Ah.53 35 Auxiliary Fire Director
Sd.Ah.54 Similar to Sd.Ah.53 but use unknown
Single Fuel Drum Trailer (Trailer designation unknown)
Twin Fuel Drum Trailer (Trailer designation unknown)
Trailers with four wheels.
Hf. 711 Large Combat Trailer (Horse drawn)
If.5 Machine Gun Wagon (Type 36 Zwillingssockel) Trailer and Tender (Horse drawn)
Vehicles
SdKfz 250 Alt and Neu all series
SdKfz 252
SdKfz 253
SdKfz 10 All series
Gun
37 mm Pak 35/36
Complete Set
Vehicle grease cap with 8 sided wrench nut. Trailer and gun grease cap with 6 sided wrench nut.
Assembled wheels showing both grease caps
Inside of wheel showing hub fitted
Fitting wheel to 2 mm Flak 30/38 Trailer. Hubs have 1/4" center holes to fit 1/4" shoulder bolts and require two 10-24 hex nuts to act as lock nuts to hold wheel in place so it will turn freely. 1/4" shoulder bolts are available in various lengths to enable fitting to scratch built vehicles and trailers. All explained in instructions that come with the wheels.
Fitting wheel to AH SdKfz 250 and SdKfz 10/4 Demag. To fit the wheels the these vehicles requires drilling out the 1/4" center hole in the hub to fit the axles on these vehicles. All explained in instructions.
Mike
Roland Wallick
Post by Roland Wallick »
Hey that looks good Mike, and may be just what I could use. I just had my suspension and steering redone in alu/steel, but I think we stopped at the spindle.
Does your hub have a bearing? Kind of hard to tell in the photo. Ill try to get you an e-mail this weekend.
Roland
Hi Roland
No bearing, but plenty of thickness in the hub to drill and place one.
Mike
