Can anyone help out with a suggestion to resolve a problem with the rotation and elevating functions that have stopped working on late Tiger I (2012). Problem started
when turret would only rotate one way and I was unable to control it with the transmitter. Same problem with elevation. Now I have no response to controls at all.
Power to both motors is OK. Could it be a transmitter or receiver problem? Thanks.
Futaba T-7CP Problem
- Has liked: 1475 times
- Been liked: 1674 times
Re: Futaba T-7CP Problem
Are you using the Armortek Auxiliary module to control the turret and elevation ?
What do you mean when you say "Power to both motors is OK", how have you tested that ?
Is the fuse for the Auxiliary module OK ? You should see a red LED on the Power Supply module if the fuse is OK. The Auxiliary connection should be the middle pair of spade connectors on the Power Supply Module.
Do you have a spare servo for testing ?
If you plug a servo in turn into the relevant channels on the receiver, you should be able to see it move when you operate the controls on the transmitter. If this works, it rules out both the transmitter and receiver as the culprits.
Thank you for your reply, Adrian, and apologies for delay in responding, but have been away. Everything is now sorted, but your advice/questions were valued. Thanks again.
