Page 1 of 4
Bergepanther
Posted: Thu Aug 28, 2014 5:58 pm
by Günter Gäbelein
Re: Bergepanther
Posted: Thu Aug 28, 2014 6:13 pm
by Paul Morris
Hello Gunter!
Excellent I love it now this is really going to be worth watching well done and please keep the pictures coming.
Cheers Paul.
Re: Bergepanther
Posted: Thu Aug 28, 2014 6:28 pm
by Iacopo Di Giampietro
Congratulations: you're doing such an amazing job and full of details.
I like it!
Re: Bergepanther
Posted: Thu Aug 28, 2014 10:05 pm
by simon_manning
well done gunter, a very interesting build, keep the posts coming, regards simon manning.
Re: Bergepanther
Posted: Fri Aug 29, 2014 11:51 am
by Pierluigi Patri
Hello Günter
you are making an amazing stuff.
My compliments
Re: Bergepanther
Posted: Wed Sep 03, 2014 6:39 pm
by William Gardeniers
Nice parts you have there Günter.
Regards William
Re: Bergepanther
Posted: Sat Sep 06, 2014 8:08 am
by Günter Gäbelein
Hi guys,
thanks for your positive feedback! In the last days I modified the rear deck. By the modification it is possible to remove the rear deck partially. Below the rear deck I added a frame, which is attached to the rear plate and to the treverse bulkhead. The new rear deck is partially modified and has all holes drilled.
Also attached is the left driving motor. Next will be the periscopes for the driver and the radio operator.
The longitudinal struts
The left motor and the longitudinal struts
The rear left intake grill is mounted
The cover behind the intake grill is glued to the frame, the cover with the exhaust fan is mounted
The left side is nearly completed
The lifting hooks for the cover with the exhaust fans will allow to lift the cover by the crane
The new rear deck
The new air scoop mounted
Thats all for today
Re: Bergepanther
Posted: Tue Sep 09, 2014 5:35 pm
by Günter Gäbelein
Hi guys,
both motors are now mounted
The drive chains can be tightened by moving the motor brackets
There will be a conflict with the drive chain and the rear bracket of the winch. I will need an own deigned bracket
Self made photo etched parts for the tab washers
The drivers periscope, not yet completed
The operators periscope
The first test run (dry) was ok, but I still have to modify the bump stops on the left side.
Re: Bergepanther
Posted: Tue Sep 09, 2014 6:03 pm
by Paul Morris
Hello Gunter.
Brilliant loving it well done!
Cheers Paul.
Re: Bergepanther
Posted: Wed Sep 17, 2014 7:20 am
by Günter Gäbelein
Hi guys,
I found a way, to animate the driver instruments
animated instrument (1MB)
Re: Bergepanther
Posted: Sun Dec 14, 2014 7:20 pm
by Günter Gäbelein
Hi guys,
I made some progress in the last weeks. I have finished my sound boxes, which are placed over the tracks below the grilles. For the sound I am using a Beier module and a frequency crossover. In each sound box I have placed one subwoover as horn and the tweeter is placed between the motors. Now I have enough space to place a replica of the upper engine.
The driver figure is already animated (head, arms), also the operator (head). The both figures in the rear compartment will be animated later.
Left sound box
Tweeter
Battery, receiver, two switches, sound module. One switch is used as circuit breaker for the main current circuit, the other for activating the engine sound.
Crew in the rear compartment
Driver, from rear compartment
Operator
Re: Bergepanther
Posted: Sun Dec 14, 2014 7:53 pm
by Günter Gäbelein
Hi guys,
here is a short movie with a sound test and the driver in action.
Sound and Driver (2.4 MB)
Re: Bergepanther
Posted: Sun Dec 14, 2014 11:38 pm
by Peter Dierckx
Brilliant!!!!
Re: Bergepanther
Posted: Tue Dec 16, 2014 9:40 am
by Rolf Mönke
Hallo Günther,
WAHNSINN !!
Re: Bergepanther
Posted: Tue Dec 16, 2014 10:12 am
by Ian Rodney
Hi Gunther,
Great to see the inner workings of your Bergepanther, and your figs look good sitting up front.
Also good to see you back on the Forum.
Keep your pics coming!
Ian
