Muzzle Break
- Been liked: 177 times
Muzzle Break
Hi Everyone
Finally took care of this. Still contemplating whether or not to do the interior of the muzzle as well. I have yet to make the washer that goes between the collar and the break.
The real thing off of Littlefield,s Panther Ausf A (missing the center-lock tab). From what I could tell, the ausf G did not have the flange on the barrel before the muzzle break and the collar is thicker on the G. This photo courtesy of Bob Morey
- Has liked: 213 times
- Been liked: 151 times
Hi Tim
That looks very good did you part the end off completly or is it a deep groove with the spanner notches milled in?
I was going to part the end off. I also noticed on photos of the real thing
there is a grub screw that looks the short end peice (Ryton panther in detail page 41 - Culver & Feist )
The only word of warning would be to those using the blank fire mechinisim I am not sure if this mod is ok with that !.
All the best
All the best
Hello Derek
Yes, I parted it completely like the real thing. You are correct, there is a set screw on the collar. I was going to add it when I completed the spacer/washer thing that goes between the two pieces.
I agree. I would strongly advise against this modification if you plan on firing blanks as the muzzle break ends up with only half the original threads.
I was thinking a spare, factory muzzle for that purpose would be the way to go to prevent any unwanted or unexpected projectiles.
some clearer pictures
HI Derek
Yes, there are four in the collar. I cut them at a 45 degree angle and approx. 1.1 mm deep(distance from edge to the back edge of the cut) The Ausf A pictured above is different then the G but it was a nice photo of a real one none the less.
The muzzle also has the same cut (only one) inline with the locking tab/thing. I need to go back and check the location of the set screw on the collar as I have seen them in various orientations in real pictures but it's centered on the flat area of collar between two of the spanner-type cuts.
Look forward to seeing your pictures.
Another great picture of the interior part I'm making.
Awesome work Tim (as always!)
As a matter of fact I think it was 2 cuts in the muzzle.
The photos below indicate that.
And don´t forget the washer for the muzzle locking bolt.
Also please note the 2 holes in the collar - probably used to grip in a tool to get the collar in place.
Bovington Ausf G
Patton Ausf G underside
Patton Ausf G side
Overloon Ausf G
It is all in the details!
Bovington Ausf G
Patton Ausf G side
Overloon Ausf G
Excellent info and pictures Kent. Thanks. Will make appropriate corrections. I need to figure out how to make a lock-washer that size for the bolt still. that's why it's missing.Kent Wiik wrote: As a matter of fact I think it was 2 cuts in the muzzle.
So they are just holes on the collar and not set screws? That's easier.
This will teach me to post things before they are completed.
Thanks Derek
Hi Tim
I have just finnished my spacer washer thing and I made two the
first was 0.62 mm thick which looked good but put out the alinement of the notches so I then made one 0.85mm thick which gave good alinement of the notches but looks a bit thick.
Do you know how thick this washer/spacer should be?
Also did you have to take a bit off the end of the barrel thread to make the
muzzle screw down fully after the parting off?
regards
regards
Hello Derek
Instead of removing from the barrel, I added material to the back end of the collar 1.5 mm which also ended up giving the chamfer a look closer to the real thing. This will depend on how thick your cutter was and how much material it removed. The space I have left for the washer is no more then .5mm. I had some scrap of really thin styrene I'll be using that measures .45mm thick. Luckily, it looks perfect!
By the way, the muzzle on mine bottoms out on the threads right on center so if it was able to be threaded on further, it would be crooked.
I'll finish it this weekend and post pictures.
Hi Tim
I have parted my washer from Brass rod I have now sorted the
alignement out I have undercut the inside of the muzzel thread
so it screws on all the way.
I did find the thread is a bit offset but I can get the 2 parts to line up
with the washer in place.
Latest pictures. I didn't have the material to fabricate the inner details yet so they'll have to wait. But I added a flange to the barrel, increased the top slot, added key-holes on collar and added a slot on the bottom of the muzzle break. Also reduced my locking tab height. Sorry Kent, no lock washer yet.
I will add the kinks(or dings like above photos from Kent) in the large, collar lock washer when I do final weathering etc.
Derek,
Look forward to seeing yours.
Derek,
