Does anybody know if Tamiya make a Deep bronze green in their TS range of rattle cans ? ,if not what is the closest equivalent.
Tamiya paint
- Has liked: 8 times
- Been liked: 701 times
- Has liked: 1038 times
Re: Tamiya paint
Short answer is no. Some say TS9 works but it's not a good match.
If you're a) mad or b) loaded or c) both of the above, you could try:
http://www.militaryvehiclepaint.co.uk/p ... t_id=61609
I guess it's so expensive because it's made to the full mil spec.
The only answer out of the box is to go for an acrylic or enamel and use an airbrush.
Xtracrylics do a good acrylic match:
http://www.hannants.co.uk/product/XA1814
And White Ensign do a very accurate enamel:
https://www.whiteensignmodels.com/p/Dee ... qDSjpBFCWs
My choice would always be the acrylic for the base coat and then use enamels and oils for weathering.
Hope this helps but I suspect you're after the one shot spray can solution - difficult.
Re: Tamiya paint
Stephen,
Thanks for the reply and links, Your right in that I was hoping for a Tamiya rattle can that was a close match but I may have to get the airbrush out and use the acrylic.
