Hi Stephen and all.
Back of the net again I would say, and so eloquently put ....
Well done that man.
Cheers Paul.
StuG III 014 - A Team Effort
- Been liked: 68 times
Re: StuG III 014 - A Team Effort
01524 720977
01524 720977
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Hi guys, the suspension arm angle, can this be adjusted to the desired value? And if so how does this work?Darren_Hagarty wrote: ↑Thu Dec 19, 2013 10:51 amSet Suspension Angle
This needs to be 30-40 degrees.
It took a fair bit of fiddling but hopefully its OK now. ......
Or is this angle grinded onto the torsionbars and is fixed ever after?
Kind regards,
Roy
Roy
- Has liked: 1182 times
- Been liked: 1378 times
With the adjustable torsion bar system, the steel plug which sits at the "fixed end" of the torsion bar (CL0222 on my earlier StuG kit) can be released and rotated to correct any change in the suspension angle from age or damage, hence removing the need to change the angle of the ground portions of the torsion bars themselves.
- Roy Beukeveld
