Late Tiger tracks
Kirk Wiggins
Late Tiger tracks
Post by Kirk Wiggins »
Hello everone,
I have encountered a problem fitting the tracks to the drive sprocket. When the teeth of the outside sprocket ring are seated in the track, there is a small perpendicular tab on the inside of the track that prevents seating on the inside sprocket ring. This, of course, creates a problem.
I could file down the tab on the inside of each track. That's certainly a lot of work that should /could have been handled during the production process. Therefore, there is probably another solution, but it escapes me.
Any help will be much appreciated.
Thanks,
Kirk
leesellars
Been liked: 15 times
Post by leesellars »
Hello Kirk
It sounds like you have your spockets inside out giveing you a larger dimention.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Kirk Wiggins
Hi Lee,
Thanks for replying. According to the directions, the drive sprocket and sprocket rings are mounted correctly. The tracks won't fit. It could be that the inside of the sprocket rings which mount to the sprocket are not cut deep enough, but no one else seems to be having the problem.
Kirk
David Ward
Post by David Ward »
Hello Kirk
The machined recess on the sprocket rings face outwards on both sides of the sprocket. Have a look at Armortek's prototype tiger photos in the gallery. Hope that helps.
Kirk Wiggins
Hi David,
That may be the solution. I have the machined recesses on the sprocket rings facing the sprocket.
Thanks,
Kirk
