why does my JagdPanther not drive
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
hi all
Hope someone can answer this
I have dismounted the Armortek soundsystem as it was defect.
This leaves these to wires disconnected from the Armourtek sound system.
Do they have to be connected to a sound system for me to drive the tank. Reason for asking is that the tank does not move, however the main gun moves after I took the defect sound and amplifier out
I am awaiting the new sound system from Armortek to arrive but would have loved to drive with the tank in the wait time
cheers
steen
cheers
Steen
Has liked: 1492 times
Been liked: 1699 times
Re: why does my JagdPanther not drive
No.
With the 4QD based system, the two leads from the DMR-203 need to go to the channels on the receiver which control the two tracks. You should then be able to drive the tank as before.
Günter Gäbelein
Has liked: 41 times
Been liked: 195 times
Post by Günter Gäbelein »
Hi Steen,
at the Sound System there should be also two cables, which were connected with the receiver. The Sound System (i.e. the Benedini) is connected to the driving and turning channel of the receiver and also the Motion Pack. If you remove the Sound System, you have to connect both channels from the receiver to the Motion Pack.
Günter
Steen Vøler
Has liked: 62 times
Thanks guys
I have reconnected and it runs again :D
Video will be posted tonight :lol:
cheers
Steen
cheers
Steen
