Testride Tiger I/45 Late and season greetings.
- Been liked: 15 times
Hallo to all,
For all Irontankers the best season greetings and a happy newyear 2013.
Here are the results too see.
http://www.youtube.com/watch?v=jD4Mv8tN ... e=youtu.be
Kind regards Gerrit and Manfred.
- Been liked: 3 times
Re: Testride Tiger I/45 Late and season greetings.
Nice trial! I hope Manfred survived the ride..
- Luc De Weirdt
- Been liked: 16 times
Looks great, Gerrit!
- Steen Vøler
- Has liked: 62 times
- Been liked: 498 times
Great video, hope the bridge survied
Greetings
Steen
Greetings
Steen
cheers
Steen
Steen
Re: Testride Tiger I High Efficiency Motion Pack.
Hallo to all,
Can anybody tell me wy the engine/gearboxes make more noise forewards and less noise backwards.
It sounds to me not good???
Kind regards Gerrit.
Hallo Steen,Steen Vøler wrote:Great video, hope the bridge survied
Greetings
Steen
yes the bridge has survied but is moved to a another place/Battlefield in Holland becuse I stoped with scale 1/16.
Thanks for the reaction.
Re: Testride Tiger I/E
Hallo to all again,
After a long period I'm back in good conditions.
My progess about the Tiger getting well.
But the right track is comming off the crownwheel and I don't no why.
Can somebody HELP me?
The tracks are build up whit 94 tracklinks.
Best regards Gerrit and Manfred.
- Been liked: 2 times
Hi guys,
Below the pictures of Gerrit's Tiger illustrating the problem with the righthand track/sprocket.
Frontview of the RH sprocket
Sideview of the RH sprocket
Sideview of the total LH side
Sideview of the total RH side
Any suggestions of the cause ?
Ad
Ad
- Has liked: 704 times
- Been liked: 306 times
I suggest chamfering the sides of the sprocket teeth. If they are already chamfered - chamfer some more. It will prevent the track from climbing. Also, make sure that the road wheels sit the same distance from the hull on both sides, since any error in mounting them will effectively steer the track to the side - oh, and the sprocket to hull distance too of course. Lastly, experiment with track tension. My experience is that too loose will make the sprocket skip, whereas too tight will make the track climb. Interesting phenomenon!
Good luck!
/Chris
Good luck!
/Chris
- Has liked: 26 times
- Been liked: 103 times
Hi Garrit,
I too have suffered the wrath of track on my T1. I noticed the left side higher than the right. I therefore will be stripping the tank down and re-calibrating road wheel angles and setting the hull level again.
Cheers Ray.
Cheers Ray.
Hello Chris/Ray,
Tanks for thinking over the problem.
I will have a look and try again to repair it.
You can feel mIne frustrations about this problem.
Best regards Gerrit.
- Been liked: 68 times
Hi Gerrit.
Get the tank back into your workshop and get the tank jacked off the floor so the tracks are clear of the ground, now remove the sprocket caps and slacken off the taper lock bushes in the sprockets .. .. you will need to losen them off and then slightly tighten them back up .. .. now VERY SLOWLY AND CAREFULLY .... start to turn the tracks one at a time if you have the taper locks just right the motion of the track will make the bush self locate in the correct position or as near as dam it .... but you MUST DO THIS SLOWLY!
Once you have the taper locks set just about right you can tighten them down, but remember the tightening of the lock will move the sprocket slightly you must account for this in your final tighten up.
Hope tis helps, remember slowly does it!
Kind regards Paul.
Kind regards Paul.
01524 720977
01524 720977
