Hi all,
I have assembled the first of my horstmann bogeys on the centurion and wonder if I have an issue?
When the unit is assembled the spring assembly does not contact the suspension arm fingers but sits free betwwen them under no compression. Have I slipped up or does the compression come on when the weight of the tank is on them? The instructions seem to suggest the spring should be compressed a little to facilitate fitting the bump stops.
Any suggestions please.
Regards Mick.
Centurion Suspension bogeys
- Has liked: 10 times
- Been liked: 226 times
- Been liked: 3689 times
Re: Centurion Suspension bogeys
Hello Mick
You should find, that if undo the stud cap (EH0212) a couple of turns, the arms will be sitting against the stop blocks (EH0208)_ and there will be a little tension on the spring.
