So... Here we go... I think we may be the first Centurion build log
We received 4 boxes on Wednesday lunchtime. We spent a bit of time sorting through the bits and trying to get our head around the construction stages.
Yesterday we moved the hull parts to the construction area and loosely screwed them together. The plan is to build the basic hull, paint it and then add to it, I'm assuming the motion pack bits will still fit trough the engine hatches and turret ring?
Will be British 60s. We're using Halfords primer but have no idea which green - any ideas?
Today I've been tidying the edges of the tool bins and filling the gaps with Milliput, they are very cleverly folded steel. Dad has been linking the tracks - very time consuming and fiddly. They look mean
Robin
PS We got 013, I hope it's not an omen
Re: Paul & Robin's Centurion
Posted: Fri Nov 16, 2012 7:10 pm
by Stephen White
Welcome guys, good to see the first Cent build. Good luck and enjoy it. The forum is great and will help with anything you need to know.
I'd strongly suggest you clean and paint each part before assembly. Cleaning can be just a sand over or use an acetone based cleaner, just to ensure a grease free surface. You are best to use an etch primer - Halfords do one called Upol Acid 8, although you can get a better price on the internet if you buy in bulk. If you search the forum, some members have found cheaper substitutes. For the period you're doing, a British Cent would have been painted in British Deep Bronze Green. A lot of model paint manufacturers do versions in acrylic and enamel or you could get a car paint shop to make some up. Depends how much you want to have an authentic model.
Hope you really enjoy your build.
Posted: Fri Nov 16, 2012 10:25 pm
by sean kerambrun
The centurion is looking good.. I am getting excited now . I can't wait for mine to arrive but I have one other (non tank) project to finish first anyway ...
Good luck with the build.. Lots of pics please
Sean
Posted: Sat Nov 17, 2012 1:51 pm
by Kevin Hunter
Hi Paul & Robin
Good to see you getting started. I too am new here and awaiting a Centurion which will ( probably ) reflect the same era as yours. Are you considering a particular regiment or unit as a subject or going "generic"?
Look forward to seeing many more pictures and hearing how you get on.
Kevin
Posted: Sun Nov 18, 2012 12:00 pm
by paul&robinmargle
Hi,
Thanks for the advice haven't done anything quite like this before (just 1:35 injection plastic).
I've been cleaning with car paint preparation wipes, should I paint all mating surfaces too?
We haven't got any specific markings in mind, just to use Paul's old number plate from his REME Commer 3-ton repair truck as a tribute.
Since the last post we've been riveting...
Robin
Posted: Sun Nov 18, 2012 12:29 pm
by Stephen White
Paul and Robin
Your tank will be better protected if you do at least etch prime the mating surfaces, particularly the steel components. One note of caution - the Workmate isn't man enough for the job once you start assembling and you really wouldn't want the hull on your feet.
A work bench is one solution but many of us have invested in an hydraulic platform. You can get them in different sizes from Axminster Tools or Clarkes. Something like this:
Hello Paul and Robin, all my metal 'parts' are cleaned with a Brillo pad, dried, and etch primed with E-Pol Acid Etch, spray. If you use a table lift, cover the table with a non slip material.....my Jagdpanther slid off on one side, metal on metal,it was an awful moment.....I will be following your build with great interest, best wishes, Mick
Posted: Sun Nov 18, 2012 9:49 pm
by Steve Stuart
I always keep half an eye on the local skips and I have rescued a fire door. This has been cut down so it has the foot print of a tank my and then bolted to the top of my lifting table. Making a secure stable location for the tank to be driven off and off.
Now to do this I have aquired a wheel chair ramp to be able to run the tank up from the garage floor and on to the lowered table. My final item was to buy a motor cycle lift to allow me to keep the tank off its tracks and also to be able to run the tank with no danger of driving it off the table....
Posted: Sun Nov 18, 2012 10:22 pm
by sean kerambrun
Hi guys,
I made a tank bench .. It uses a 12V linear actuator to lift the tank. This was during testing.. I have finished it now, I must upload new video.
I am going to make another one.. A little differently as you always learn as you go
Sean
Posted: Tue Nov 20, 2012 10:51 am
by paul&robinmargle
Has anyone used this paint?, I suspect you can get cheaper but the colours are authentic and they say very tough:
After a week at work I headed back to the parent's place - or the 'Centurion workshop' as I now call it
The weather has been quite bad, the hull in the shed was getting covered in condensation so we brought it in from the cold to the spare room - just temporary.
Here is 100 links
Riveted side bins
We managed to create some tools for riveting, drilled a dimple in a piece of metal to keep the domed head during the hammering. It took one of us to hold the pieces together while the other hit them.
Detailed bins
I got some Evergreen quarter round strip for the raised strip on the lids, couldn't find big enough half round
To make the handles look flattened and welded I used a small piece of plastic and some Milliput.
We found some Upol acid #8, it seemed quite runny when I tested it out, I think it needs more shaking up
It seems the same as Halfords ordinary primer, is there much difference?
Robin
Posted: Sun Nov 25, 2012 6:33 pm
by Stephen White
Robin
Etch primer is very different from a primer. It has a combination of acid and zinc in it which chemically combines the zinc with the surface of the metal, which means it provides a much more effective bond. It has to be used on bare metal. Etch prime is intended to be applied in a very thin coat, not to build up depth. If you want a sanding surface, use an ordinary or a high build primer once the etch prime is dry.
I'd recommend using an etch prime whatever else you do. You can then build up a coat of ordinary primer which can then be sanded. If I need a textured surface, I use etch prime, followed by high build prime, with a coat of ordinary primer on top to key the base coat of colour. I then seal that with a satin clear paint so that the weathering can then sit on top.
I'll post something on my Cent thread.
Posted: Sat Dec 01, 2012 10:04 pm
by paul&robinmargle
We were hoping to get priming the main hull parts this weekend, but it's been a bit cold. So we did yet more riveting.
After a lot of thought I decided making workable bin catches was beyond my skill, so I'll attempt some resin casting.
the master catch
I'll also do the filler caps.
Robin
Posted: Sun Dec 09, 2012 1:22 pm
by paul&robinmargle
Hello,
Weather's still not ideal, we've been cleaning parts and opening the holes in the rollers, very few of the shafts fitted.
Paul test built a bogey.
Today we finally got paint on, albeit just the roller houses, it feels more like we're getting somewhere.
There was a bit of a failure with my first resin mould making attempt, didn't set - have tried again. Anyone have any experience with this?
Feel free to comment on my previous work bearing in mind I'm not as advanced as most
Robin
Posted: Sun Dec 09, 2012 1:31 pm
by sean kerambrun
Hi Robin,
You are doing great.. It is going to look awesome.
Knowledge comes with experience and time. That's how everyone starts.
I have just opened the boxes and had quick look.. I don't think the assembly will be too hard for me it is the detailing and weathering that has me thinking ......
