This is the speedo and the temp/oil cluster kindly provided by Dave Dibb.
This is the tachometer that goes into the left-hand side of the dash. I've cleaned up the image and it looks fine. It prints just about to scale, the real face is about 70mm across. You may have to tweek it to fit the Atek dash.
Will post an image of the voltmeter when I get mine back.
If there are any images of the switches/vent controls etc that you would like to see they could be posted here too.
