sound module wiring
steve haddrell
Been liked: 1 time
sound module wiring
Post by steve haddrell »
I have just received the Benedini sound module for my late Tiger. How is it wired in? I've looked at the schematics and can't work it out. The three input leads are all the same - how do you know what channel each one goes in the receiver? Likewise on the output from the sound unit - which sockets on the back of the unit do you attach the speed contoller cables to and which way up do the plugs go?
Confused.com
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hi Steve,
Assuming that you purchased the combined Benedini/Armortek sound module and amplifier, the wiring-up is as follows.
Put the metal box in front of you with the input and output leads on the left (big grey input plug on the top)
Input from the top:
1) Power input (already plugged in through the red/black lead with the big plug entering the box from the right.
2) To be connected to your receiver channel for speed controller 2 (probably channel 1 - left stick up/down)
3) To be connected to your receiver channel for speed controller 1 (probably channel 3 - right stick up/down)
4) To be connected to your receiver channel that you allocated to the control of the sound module.
Output:
1) To your interface (DMR 203) "INP 1"
2) To your interface (DMR 203) "INP 2"
3, 4, 5, 6 are not used in this basic set-up
7) Signal to the amplifier (already plugged in and led through the box to the amp)
For all plugs: the orange wire should always be on top.
Hope this helps a bit.
Ad
steve haddrell
Been liked: 1 time
sound module wiring
thanks Ad
