Late Tiger Track Sprockets
Jonathan Barker
Post by Jonathan Barker »
Hi this is my first attempt at using forum.Nearly finished my first project of this type. Has anyone found the gap between drive sprockets is too narrow for the tracks. I have reversed the outer ones and packed them out with shims to widen the gap - not ideal as the inner recess ring in now on the outside.
David Ward
Post by David Ward »
Hello Jonathan
If I have understood correctly, I think you have put the rings on incorrectly. The recess on the ring should be on the outer face of the sprocket.
David Gray
Been liked: 1 time
Post by David Gray »
hello Jonathan
i think David is right . i have just tested a piece of track on a
sprocket and there is about 1mm clearance with the track
engaged on the sprocket
dave gray
Jonathan Barker
Thanks Davids. Yes this will provide the right gap I am sure - it just didn't seem right.
