Hi All,
Had a go at some welding on my T34/85 kit, using Rapid Bond Metal Epoxy from B&Q. Not bad stuff to use but you got to move fast before it goes hard!
Ian
from Glasgow, Scotland
WELDS FOR T34-85
- Been liked: 53 times
- Been liked: 177 times
Re: WELDS FOR T34-85
Hi Ian
Welds look great! Nice job.
- Has liked: 1495 times
- Been liked: 1699 times
Good looking welds Ian.
I've used JB Rapid a few times but that's going stiff before you've even mixed it properly. Because of the colour it goes when mixed, it reminds me of just melted chocolate.
Hi Tim & Adrian,
Thanks for your encouraging comments on my attempts at 'Welding' I know that I don't need to be so neat and tidy on the T34s as one does on the German tanks etc....But I'm pleased with my results so far and will be continuing my weldings on the upper hull and elsewhere.....
As long as I can keep moving fast using the Rapid bond metal epoxy, I should get better welds done. Mind you some of welds do end up on the floor if I move to fast?
I also use Milliput on others areas that won't get he same pressure, rough treatment like the Rapid bond on areas that will get a good bashing when the tank is on the move on rough ground etc....of course using Milliput, you get a far long time to handle it, and getting it into place!
Still it's fun creating welds, and I myself appreciate all you guys and girls out there creating your own welding methods as I've seen on the Forum.
Ian
Ian
