Flexible Antenna Mount for SDKFZ 222 and 7 and other
Martin Diessel
Been liked: 21 times
Post by Martin Diessel »
Heve a few leftover on own made flexible antenna mount for the SDKFZ 222 and SDKFZ 7. These are nearly matching the OEM size used on the wheeled vehicles such as Kübelwagen and many others. So its possibel to install a fully isolatet antenna w/o interferrences from the vehicle. They can be also used on 1/10 or 1/12 scale tanks for the regular antenna. Please note these are home-made and no large industrial production runs! All bases have a hole trough to allow installing the antenna cable. Following leftovers:
Antennabase with treaded 3mm pipe for srew on mounting and 3.8mm adapter to fit Mikes S. Antenna asking EUR 15.-- (Mike S Antenna not includet)
As above w/o atenna adapter asking EUR 12.--
Flexibel base only asking EUR 6.--
Plus shipping as per your request. Shipping wordwide exept Italy!
Martin
mit antenne.JPG (136.63 KiB) Viewed 789 times
am turm~1.JPG (152.12 KiB) Viewed 789 times
