REPLACING RUBBER TRACKS
- Has liked: 59 times
- Been liked: 33 times
Recently had to replace the rubber tracks on one side of the halftrack. I replaced everything as before but after running I find that the track will not centre in the idler wheel and rubs on the ally. Neil the original builder had the tracks pefectly centred so that even the paint did not rub off. I have repeated the process several times but cant get this aspect right and am gutted to spoil a mint model. i cant see that wear is an issue but neither can I see what allows the track to run centrally in the idler. Has anyone had the same problem and come up with a solution?
- Been liked: 3377 times
Re: REPLACING RUBBER TRACKS
Hello Peter
On the US half track model, the roller chain runs in the central groove of the idler wheel. There is no provision to make it run dead centre, and it is quite normal for the pins to rub the face of the idler groove. I'm fairly sure the same is true of the full size vehicle.
Thankyou Mark for the information. I am in the process of contacting Neil to establish how he managed to get the tracks to run precisely centrally without even damaging the paint let alone the ally idler wheel! Must have a magic touch.
