After a couple of years gap, i have finaly got around to doing some work on my 222 and my atempt at a 221. i thought i would try some brass work, i have made door boxes back boxes and rear boxe, as well as light guards, fuel can holders and ammo box holders. i have also made Dave Dibbs excellent german tool holder set up. Daves stuff is brilliant and much easier to made than i thought, i did chicken out and used plastic strip for the pins as i will need a master class from Simon manning before i can solder them together !
These are my first crude atempts.
Back to the 222
- Has liked: 795 times
- Been liked: 8 times
Back to the 222
- testb 001.JPG (890.79 KiB) Viewed 7241 times
- test 485.JPG (956.95 KiB) Viewed 7241 times
- testb 003.JPG (699.09 KiB) Viewed 7241 times
- test 480.JPG (957.61 KiB) Viewed 7241 times
- test 477.JPG (879.86 KiB) Viewed 7241 times
- Been liked: 3 times
Re: Back to the 222
Nice work! Looking forward to see more
Re: Back to the 222
I have done some more work on my 222, i have added weld lines on this one, but i think i will keep my other one which will be an earlier 221 (hopefuly) smooth, ie the welds were ground down in production. Dave Dibb kindly gave me some six sided strip for small bolts so i have added them as well. hope you like the work.
- 222 updae 003.JPG (1.05 MiB) Viewed 7104 times
- 222 updae 002.JPG (932.83 KiB) Viewed 7104 times
Re: Back to the 222
Since it was 31 degrees here in Salisbury today, i got around to digging the spray gun out, 2 hours cleaning and fiddling around and 10 minutes spraying. Base yellow, boring i know but thats the german coulors.
- 222 updae 006.JPG (1.21 MiB) Viewed 7103 times
- 222 updae 005.JPG (1.19 MiB) Viewed 7103 times
- 222 updae 004.JPG (1.19 MiB) Viewed 7103 times
