zimmerit
JEANPAUL RIALLAND
Been liked: 2 times
zimmerit
Post by JEANPAUL RIALLAND »
hi guy
J have a question because there's nothing in France for 1/6
I want to put on my Tiger Zimmerit how I can do ?
thank you very much
jp
Paul Morris
Been liked: 68 times
Re: zimmerit
Post by Paul Morris »
Hello Jeanpaul.
I have always used "Milliput" a two part epoxy putty, you can get it from most craft type shops or on Ebay through "Ancestral dawn" they are very good price wise, and always been very fair with me.
Some of the other guys have used tile adhesive and got very good results also, in fact I have now tried this and it is a very fast way of doing it.
Hope this helps out.
Kind regards Paul. :wink:
01524 720977
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: zimmerit
Post by Steve Norris »
Hi Jeanpaul,
As Paul has aready said, Tile adhesive produces very good results and it is also a lot quicker than Milliput. If you decide to use tile adhesive i would recomend that you purchase a set of Mike Stannards Zimmerit tools (http://www.6thscaleicons.com/)
Simon Peck
Has liked: 7 times
Been liked: 46 times
Re: zimmerit
Post by Simon Peck »
Hello All.
Has anyone tried the Milliput versus the tile adhesive method. I like the tile adhesive option, but how durable is it as compared to Milliput?
Simon.
John Fitzsimons
Has liked: 5 times
Been liked: 734 times
Re: zimmerit
Post by John Fitzsimons »
I have recently worked on a tile adhesive covered tank and found it chipped easily. Had to replace some faces of the armour with milliput.
Milliput takes longer to apply and it takes quite a few packs.Make sure the milliput is well mixed. I roll out sheets between sheets of grease proof paper with an old rolling pin. Work on the pattern with various paint scrapers that i have cut to suit the patterns.
Last edited by John Fitzsimons on Wed Jun 13, 2012 1:58 pm, edited 1 time in total.
Simon Peck
Has liked: 7 times
Re: zimmerit
Hi John. I thought that might be the case. I know milliput is harder to work with in this instance, but the durability is worth considering, (for me at least). Thanks.
John Fitzsimons
Has liked: 5 times
Re: zimmerit
Get you milliput on ebay. There are a few sellers selling in packs of ten. You will get through it.
Peter Quambusch
Been liked: 1045 times
Re: zimmerit
Post by Peter Quambusch »
I use two-component body filler (for cars). It´s a bit messy to apply, but the durabillity is (at least for me) quiet all right (and it´s cheap too).
To apply I used a putty knife ana a saw-blade for the rough surface.
