Her arrival.
The workshop.
Mate are you saying the adjusting screw never leaves the hull? So if I turn the brass cup around and place the screw inside the hull I should be right?John Fitzsimons wrote:Make sure the head of the adjusting screw is inside the cup and not screwed in from outside the tank.
