Outer Bogie Wheels no turning
I have one of the early production mid tiger 1 and my outer bogie wheels do not have enough weight/contact with the tracks to rotate consistently. I realize the wheel arms are not completely parallel with the ground so am working on this. Any suggestions on this problem would be welcome. Thanks.
- Been liked: 741 times
Re: Outer Bogie Wheels no turning
Hello Ramon,
Did you check your suspension arms? Maybe they are comming loose?
I secure my suspension arms with loctite ( green= very strong ) and drill
on both sides of the arms a hole and put a pen in.
Here is a picture
Uploaded with ImageShack.us
Hope this will help you
best regards Yves
Here is a picture
best regards Yves
- Has liked: 1490 times
- Been liked: 1697 times
If you have the original cast suspension arms, which I believe were machined in India, they could be out of true at both ends, compounding the problem.
A set of Mark's in-house machined arms should line things up a treat.
