Hello,
I've run across something assembling the electronics.
I seem to be running short 1 connector in the power distribution loom.
I have the following accessories to plug:
Fire Power loom
Turret connector (8way)
FR12 ESC
Sound Unit
Smoke Unit Element
Smoke unit fan
Problem is I only have 5 plugs
2 from the fuse box, one of them connects to the Turret connector and gives you a few splits, but the total amount is still 5.
Do I have the wrong power loom or is it common to have to splice the 6th?
Power distribution loom 1 connector short?
- Been liked: 1 time
- Been liked: 177 times
Re: Power distribution loom 1 connector short?
Hi Raymond
No splicing was necessary on mine. If I understand you correctly, your "fire power" loom is for the blank firing unit motor? I thought this was part of the turret loom.(shown on page 15 of assembly instructions)
also here (yellow and white)
sorry if I am misunderstanding the question
good luck
good luck
