g'day all.
this is the first time working with brass strips & small aluminum. i have no problem soldering but how do i solder brass? i'm making jerrycan brackets but also other little things.
thanks
ray
working witth brass pieces
- Has liked: 1479 times
- Been liked: 1683 times
Re: working witth brass pieces
Ray, Dale Jordan did a couple of threads on soldering brass here:
http://www.armortek.co.uk/Forum3b/viewt ... ?f=6&t=528
http://www.armortek.co.uk/Forum3b/viewt ... ?f=6&t=529
- Has liked: 26 times
- Been liked: 103 times
thanks adrian, that is great tutorial by dale. helped immensely.
cheers
ray
cheers
ray
- Has liked: 6 times
- Been liked: 801 times
Hi Ray. I used this tutorial also. Useful items to have are surgical clamps. I solder both parts then hold in place with the clamps and heat with gas torch. Using the clamps on the already joind parts helps them stay joined when you heat another part. I also insulate the already soldered parts from current work with some wet tissue.
