Idlers
John Wiggins
Has liked: 257 times
Been liked: 147 times
Idlers
Post by John Wiggins »
Hi
Hope somebody is going to start another Firefly, soon, I need to pick someone's brains!
I am playing with the idler. When I pass the idler shaft through the bearings and secure with the end cap and a M4x10 (not M5x10, maybe typo in the instructions? ), the wheel will not revolve ! Help what do I do next? :shock:
Thanks in advance
John
leesellars
Been liked: 15 times
Re: Idlers
Post by leesellars »
Hello John
You might have tightened up too tight. Put some loctite on the csk and put in till tight then back off till it moves freely and let the glue dry.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
chris fry
Been liked: 525 times
Re: Idlers
Post by chris fry »
hello john,
you could try and put a small m4 washer behind the large steel washer then do it up, its usually the large washer pinching up on the wheel bearings, the small washer will just give you a little gap from the bearing, you can try what lee said but specking from experience any loctite on those bolts just leads to problems when you want to take the wheels off in the future,
cheers, Chris.
John Wiggins
Re: Idlers
Thanks Lee
I wished I new what I'm doing, but it's great fun!
Just putting things together, to understand how they work, before painting and final assembly.
Next up is the taper lock on the sprockets, should be fun. :roll: :lol:
John
Has liked: 1495 times
Been liked: 1699 times
Re: Idlers
It may be the bearings aren't fully into the recesses in each side of the idler.
If you haven't already bonded them in place, see if there is any swarf or tightness in the idler which is preventing them from dropping fully to the bottom of the recess.
John Wiggins
Re: Idlers
Hi
Had another play, last night, decided that the problem was friction between the end of the steel shaft and the idler. Solution was to sand the wheel.
Thanks for your sugestions and help.
John
