OPEN ON THE 6TH FEB 2025
Sturmtiger Parts Now Available For Order
Mike Stannard (toyrific)
Hi Guys
The Sturmtiger parts listed are now available with limited quantity of parts in stock. Front mudguards, 20 Ton Jack and Driver Periscopes are still in production stage and not available. Orders for parts in stock may not be delivered until sometime in February 2012.
Here are pictures of new parts and prices. There are two parts I am not able to complete at the moment until I have seen the design of the Armortek Sturmtiger. These are the front mudguards and the driver periscope mounts. For other parts that are common to the Sturmtiger from the Tiger Series and General AFV parts see the updated Quick Guide at the end of this post.
TT01-01SMW Sturmtiger Hammer (Metal Head Wood Handle)with fittings $27.50
TT01-01SMWK Sturmtiger Hammer Hammer as a kit with wood handle Fitted $17.50
TT01-02SMW Sturmtiger Axe (Metal Head Wood Handle)with fittings $25.00
TT01-02SMWK Sturmtiger Axe as a kit with wood handle Fitted $15.00
TT01-03SMW Tiger 1 & Sturmtiger Shovel Short Handle (Metal Head Wood Handle)with fittings $30.00
TT01-03SMWK Tiger 1 & Sturmtiger Shovel Short Handle as a kit with wood handle Fitted $20.00
TT01-05SMA Sturmtiger Long Pry Bar (Metal) with fittings $20.00
TT01-05SMAK Sturmtiger Long Pry Bar (Metal) as a Kit $15.00
TT03S Tow Cable Set. 2 Tank Cables 1 Track Cable (All Tiger Series) $90.00
TT03SK Tow Cable Set. 2 Tank Cables 1 Track Cable Kit (All Tiger Series) $60.00
TT04-02S Sturmtiger Jack Block Set Assembled Wood Block Brass Fittings $60.00
TT04-02SK Sturmtiger Jack Block Set in Kit Form Wood Block Brass Fittings $35.00
TT05-02SA Sturmtiger "C" Shackle, with working wing nut. $35.00
TT05-02SAK Sturmtiger "C" Shackle, with working wing nut kit. $25.00
TT36SA Sturmtiger Snow Shovel $35.00
TT36SK Sturmtiger Shovel Kit $22.50
TT34-06 Tiger 1, 2 & S/tiger Road Wheel Extra Lock Bars Late Type $75.00
TT34-07 Sturmtiger Running Gear Lock Bar and Tab Set. Feb 44 to end $110.00
TT48A Tiger 1 & Sturmtiger Engine Air Intake Cover $125.00
TT48K Tiger 1 & Sturmtiger Engine Air Intake Cover as a Kit $60.00
TT49-03F Sturmtiger 20 Ton Long Jack Functional w/working brackets Assembled $240.00
TT49-03FK Sturmtiger 20 Ton Long Jack Functional w/working brackets as a kit $170.00
TT49-03S Sturmtiger 20Ton Long Jack Static w/working brackets Assembled $170.00
TT49-03SK Sturmtiger 20 Ton Long Jack Static w/working brackets as a kit $125.00
TT49-03R Sturmtiger 20 Ton Long Jack Resin cast body w/working brackets Assembled $90.00
TT49-03RK Sturmtiger 20 Ton Long Jack Resin cast body w/working brackets as a kit $65.00
Note the jack looks to long due to the Viper Tiger it is mounted on having the exhaust covers set to wide.
TT50 Sturmtiger Spare Antenna Rack $30.00
TT50K Sturmtiger Spare Antenna Rack Kit $15.00
Here is a new Quick Guide for the Sturmtiger.
Mike
