Which is Correct
Ken Molchanow
Been liked: 21 times
Which is Correct
Post by Ken Molchanow »
Just started working on the engine deck. I noticed or at least by “The Modeler’s Guide to the Tiger Tank” that the opening for the ventilation slot is in a different spot. Which is correct??
If I do move it will there be any clearance problems with the Turret.
Ken
"You can lead a horse to water but a pencil must be lead".
Soupy Sales
2010 Mid-Tiger Nr. 045
Has liked: 1365 times
Been liked: 1564 times
Re: Which is Correct
Hi Ken.
I haven't made this mod myself yet but both Doug Pinkerton and Rich Stinchcomb have moved the slot forwards with no apparent problems.
Rocky Sembritzky
Post by Rocky Sembritzky »
Ken,
The attached picture shows the correct mounting position. The red outline shows the Armortek position.
It will not interfere with the turret.
HTH,
Rocky
Ken Molchanow
Thanks for the answer guys.
Have to figure out, what is the best way to cut the opening out of the plate and then re-weld it. Will post the results.
Maybe this mod can be added to the “To Do” list before the next batch of late models come off the assembly line.
Ken
Soupy Sales
Mike Kasputis
Been liked: 54 times
Post by Mike Kasputis »
The picture that Rocky posted is the mod that I made to my Tiger.
If you go here http://armortek.co.uk/Forum3b/viewtopic.php?f=6&t=1219 you can see the mods I made on my mid Tiger.
Ken Molchanow
Well here what I ended up doing to correct the position of the ventilation slot on the engine hatch. I cut out the entire slot and turned it around. I have access to a good MIG welder so I was able to weld it back together with no problem. The handles that I received with the kit were aluminum; I made new ones from welding rod and welded them to the hatch.
Ken
Soupy Sales
Very neat solution Ken :D
