Need a little help on a few aspects of the late cupola for the Tiger 1 and the Panther cupola. Any help would be appreciated.
Tiger 1 Late Cupola
There are square stand off nuts around the inside of the cupola between each periscope, these I have deduced from a drawing are to hold a ring around the cupola interior, this I figure is for forehead rests when using the periscopes. I have not been able to find a real picture of this ring and would like to know if my assumption is correct and how the rests were fitted, were they individual rests in line with each periscope or did the complete ring have a cushion. A real picture would be a great help.
Real picture of stand off nuts.
Drawing showing ring.
Panther Cupola
Question 1
Anyone have a picture of the cupola hatch interior, trying to find out what the center of the head cushion looks like as the drawing I have shows a hole in the center, I guess to give access to the hatch/arm securing bolt.
Question 2
In the first picture there is a clock dial, what was it for, it does not seem to appear on all cupolas. Behind the dial is a cog, did this part rotate for some reason. It appears that the dial is engraved in the metal, can anyone confirm.
Question 3
What was this part for, it looks like it could be a turning mechanism for the clock dial. But there is no handle, is this part complete in the picture or is the lower part missing. Picture of complete part would be great.
Question 4
Is this part of the cupola, if so what is it used for.
Question 5
Does anyone have the complete drawing below showing the bottom part of the hatch lifting/locking mechanism.
Thanks for the help in advance.
Mike
