Paints
Ray Brown
Has liked: 26 times
Been liked: 103 times
Paints
Post by Ray Brown »
G'day,
what brand of paint do people use when painting and detailing their tanks. i've been using mr hobby acrylic on my 1/35's.
is vellejo any good? i've been loking through their website and they seem to have all the weathing and detailing paint.
i'm getting the P4.
cheers
phil fitzpatrick
Been liked: 223 times
Re: Paints
Post by phil fitzpatrick »
G'day Ray.
I use Lifecolour acrylics using air brush.
Valejo have a very good range as you say and every bit as good as
the others like Mr, Hobby,Tamiya,Humbrol etc.
A lot of people get spray cans made up once they have chosen a colour
or colours,especially for bigger areas,usually from suppliers of autobody paints
etc,in acrylic or other types.
Hope this helps a bit,have fun with your Panzer build
John Fitzsimons
Has liked: 6 times
Been liked: 801 times
Re: Paints
Post by John Fitzsimons »
Hi ray,
i spray everything with etch primer first then primer over this. I have started to use army painter dessert sand spray as a base coat cover as the tiny tamiya spray cans would be too expensive. every thing finally airbrushed with tamiya dark yellow XF60. It takes quite a few pots of XF60. I got about 12 pots. I have also mixed some lighter and darker shades of XF60. i prefer to use vallego and think I would go with it next time. I think vallego has a little more green pigment in it.
Ray Brown
Has liked: 26 times
Re: Paints
Post by Ray Brown »
howmuch are the vellego paints?
John Fitzsimons
Has liked: 6 times
Re: Paints
Try this supplier
Maelstrom games uk
They ship worldwide. Postage usually free
Do not bother with the airbrush paints. The basic model colour thinned down is as good.
leesellars
Been liked: 15 times
Re: Paints
Post by leesellars »
Hello Ray
For painting you can go down the rattle can route and ask the paint supplier to mix up the shade for you Or you can go down the Airbrush route.
For me the airbrush way is best as you can get the same shade of paint anywhere around the world.
I use a mixture of acrylic paints just tamiya (XF) and vallejo (Black top) range of paints. I also seal the work with a matt Varnish. So the tanks can run outside in the rain when you get cought out.
There is a bit of an out lay:
1 compressor Industrial
1 Regulator
Hoses
Airbrushes ( more than 1)
Cleaners and consumables
On avereage around £500.00.
The reason i use these paints is i ship my commisions around the world and so the customer can easily touch them up when needed.
Hope this helps
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Ray Brown
Has liked: 26 times
Re: Paints
Post by Ray Brown »
g'day,
already got the compressor, spray guns and other bits n peieces. Already got the panzer colors organised just looking for detailing aints and techniques.
cheers
Has liked: 1038 times
Re: Paints
Ray
If you look at my Pz III thread, I've shown some techniques such as the use of filters and washes. If you want some more detailed guidance AK Interactive do a series of DVDs. Although they're aimed at the plastic kit fraternity, they can be used just as well on our models. That's as long as you use acrylics for the base coat and then use enamel based paints and oils for weathering. I would apply the base colours, seal them with an acrylic varnish and then weather. If you try to apply a varnish over the weathering, the results can be pretty unpredictable.
