Sturmtiger Parts Available For Early 2012
Mike Stannard (toyrific)
Hi Guys
Planning ahead I will be working on modifying current parts for the Sturmtiger, there will also be some new parts in the future. New artwork for photo-etched brackets for tools and accessories has been done and are currently on order with the photo-etch company, should have them in about 3 weeks.
Here is the list of parts that will be available for the Sturmtiger, all parts listed are the same as on the Tiger 1, some have different mounting brackets. Taking orders now for delivery in early 2012.
Some unique Sturmtiger item prices subject to increase once parts are made.
TT01-01SMW Sturmtiger Hammer (Metal Head Wood Handle)with fittings $27.50
TT01-01SMWK Sturmtiger Hammer Hammer as a kit with wood handle Fitted $17.50
TT01-02SMW Sturmtiger Axe (Metal Head Wood Handle)with fittings $25.00
TT01-02SMWK Sturmtiger Axe as a kit with wood handle Fitted $15.00
TT01-03SMW Tiger 1 & Sturmtiger Shovel Short Handle (Metal Head Wood Handle)with fittings $30.00
TT01-03SMWK Tiger 1 & Sturmtiger Shovel Short Handle as a kit with wood handle Fitted $20.00
TT01-05SMA Sturmtiger Long Pry Bar (Metal) with fittings $20.00
TT01-05SMAK Sturmtiger Long Pry Bar (Metal) as a Kit $15.00
TT04-02S Sturmtiger Jack Block Set Assembled Wood Block Brass Photo-etched Fittings $60.00
TT04-02SK Sturmtiger Jack Block Set in Kit Form Wood Block Brass Photo-etched Fittings $35.00
TT04-03 Tiger 1 & Sturmtiger Starter Crank Set $40.00
TT04-03K Tiger 1 & Sturmtiger Starter Crank Set as a kit $25.00
TT05-01 Tiger 1 & Sturmtiger ‘U’ Shackle Set of 4 $30.00
TT05-02SA Sturmtiger "C" Shackle, with working wing nut. $35.00
TT05-02SAK Sturmtiger "C" Shackle, with working wing nut kit. $25.00
TT23S Sturmtiger Front Mudguards $275.00
TT23SK Sturmtiger Front Mudguards as TT23 as a Kit $165.00
TT25 Tiger 1 & Sturmtiger Rear Mudguards Late Type $250.00
TT25K Tiger 1 & Sturmtiger Rear Mudguards Late Type as TT25 as a Kit $150.00
TT27 Tiger 1 & Sturmtiger Engine Grill Covers Set of 4 $110.00
TT27K Tiger 1 & Sturmtiger Engine Grill Covers Set of 4 as a Kit $60.00
TT28S Sturmtiger Driver Twin & Commander Periscope (External Detail) $45.00
TT36SA Sturmtiger Snow Shovel $35.00
TT36SK Sturmtiger Shovel Kit $22.50
TT34-06 Tiger 1, 2 & S/tiger Road Wheel Extra Lock Bars Late Type (100 Plus Lock Bars) $75.00
TT34-07 Sturmtiger Running Gear Lock Bar and Tab Set. Feb 44 to end $110.00
TT43 Tiger 1& Sturmtiger Rear Deck Engine Covers Latches Set of 3 $65.00
TT43K Tiger 1& Sturmtiger Rear Deck Engine Covers Latches Set of 3 as a Kit $45.00
TT44 Tiger 1 & Sturmtiger Rear Deck Center Cover Prop Open Latches Set of 2 $50.00
TT44K Tiger 1 & Sturmtiger Rear Deck Center Cover Prop Open Latches Set of 2 as a Kit $30.00
TT48A Tiger 1 & Sturmtiger Engine Air Intake Cover $125.00
TT48K Tiger 1 & Sturmtiger Engine Air Intake Cover as a Kit $60.00
TT49-03F Sturmtiger 20 Ton Long Jack Functional w/working brackets Assembled $240.00
TT49-03FK Sturmtiger 20 Ton Long Jack Functional w/working brackets as a kit $170.00
TT49-03S Sturmtiger 20Ton Long Jack Static w/working brackets Assembled $170.00
TT49-03SK Sturmtiger 20 Ton Long Jack Static w/working brackets as a kit $125.00
TT49-03R Sturmtiger 20 Ton Long Jack Resin cast body w/working brackets Assembled $90.00
TT49-03RK Sturmtiger 20 Ton Long Jack Resin cast body w/working brackets as a kit $65.00
PP03 Tiger 1-2 & Sturmtiger Prisms 1 Unit (For TT28, TT28S, TT33 and Pan15) $15.00
GENT002 Fire Extinguisher Set (Late Type) $45.00
GENT002K Fire Extinguisher Set (Late Type) as a Kit $25.00
GENT007A Antennenfuss (flexible base) without wing nut and strap (For GENT008a & b) $18.00
GENT007B Antennenfuss (flexible base) with wing nut and strap (For straight rod antenna) $25.00
GENT008B 2m Stab Antenna with strap and wing nut. $20.00
Gent020 2 Padlocks in Kit form $15.00
IDF01 Large Type 1 ID Flag 6” x 13” $14.95
ZIMTOOL01 Zimmerit Tool Set 1 (22 teeth to 2”) Blades 2”, 1” and 1/2” $20.00
ZIMTOOL02 Zimmerit Tool Set 2 (18 teeth to 2”) Blades 2”, 1” and 1/2” $20.00
ZIMTOOL03 Zimmerit Tool Set 3 (16 teeth to 2”) Blades 2”, 1” and 1/2” $20.00
Here is a temporary Quick Guide for the Sturmtiger. For some reason I am not able to link the image to the forum
Mike
