Mid tiger 1 outer bogie wheels
Ramon Mendoza
Post by Ramon Mendoza »
I just finished my mid tiger 1 and the outer bogie wheels are barely touching the tracks so they dont roll when the tanks are running except on soft uneven ground. Any advice would be appreciated. Thanks in advance.
leesellars
Been liked: 15 times
Re: Mid tiger 1 outer bogie wheels
Post by leesellars »
Hello Ramon
Is it the original Mid Tiger or the recent one. Ie cast or machined wheels
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Ramon Mendoza
its the original midtiger 1 but with upgraded suspension (square torsion bars.)
leesellars
Hello Ramon
It was a problem with the cast wheels due to center bearing being a loose fit and not being machined in the center. Also there was a problem with the axle not being machined at 90' to the bar.
Also it is best if you machine the spacers so that the wheels dont foul the axles. If i remember i took a far bit of meat off the spacers
Lee
Ramon Mendoza
Thanks Lee I appreciate the advice!
