Ok guys, due to a lot of requests, I have uploaded some measurement pics of various parts of the '34...
First this is the front tow hook, size and shape. From the 8 or 9 T-34/85s I have personally inspected, this was the most used... it matches the rear...
Length is 10.75 inches... height just over 5 inches.
Location of the vision slit and pistol port:
Vision slot from top of turret: 1 ft. 1 inch
Pistol Port Plug Center from top of turret: 1 ft. 7 inches
Width of vision slot: 4 inches
Width of pistol port plug: 3 inches
Depth of pistol port plug (removed): 3.5 inches
Protrusion on pistol port plug (installed): 1 inch top, < .25 bottom
Center of Pistol Port Plug (along turrent jib line from edge of mantlet): 3 ft. 9 inches
Rear tow hooks:
Same length and depths as fronts
Another picture, left side:
Picture of front head on:
Hope this helps... when we get her out we will get a sample of the engine, engine start, and track sounds...
This is a late '44 tank, but has had post war upgrades, which is mainly the light and horn addition.
PLEASE REMEMBER if you are doing a T-34, you can rarely model to much dirt... and oil on the back under the exhaust. The dirt you see is just from driving across dry turf with grass! This this is a 38ton launch "cookie" cutter and its gets dirty everywhere!
Thanks guys! If anyone comes up with some templates from these, I'd sure appreciate a copy, as well as pistol ports if someone makes them!
Dave Bane
Eastern Indiana Tank Collection
