Futaba 7c
Jan_Donadoni
Been liked: 6 times
Futaba 7c
Post by Jan_Donadoni »
Hello,
I need some help.
I've got a Futaba 7c set. Everything is fine, BUT how to get it out of the mode 1 or 2 scheme?
That is, where to get the springs and leverage system that allow BOTH sticks to return to neutral position? And also, which is the ordering code for Futaba?
I like to drive the single tracks on each stick, but the Tx units are always available only in mode 1 or 2.
My men can eat their belts, but my tanks have gotta have gas.
(George S. Patton)
John Fitzsimons
Has liked: 6 times
Been liked: 801 times
Re: Futaba 7c
Post by John Fitzsimons »
Here is a link I posted a while ago. Just need return spring set.
http://www.armortek.co.uk/Forum3b/viewt ... f=2&t=3000
If you contact shop He can supply the part for the 7C. Or I can try to get you.
John for
Jan_Donadoni
Been liked: 6 times
Re: Futaba 7c
Thanks.
It looks it's for the 6EX.
By the way it is not available....
(George S. Patton)
robert michael hilton
Re: Futaba 7c
Hello Jan, I obtained my return spring kit, for my 7c, from Mikes Models, Kingstanding, Birmingham. He does mail order...Futaba Spring Return kit for ST 3G, part number Y-MA8036....most good model shops stock these kits.
I found that control of the tank tracks so much easier when both sticks returned to center......Mick
John Fitzsimons
Has liked: 6 times
Re: Futaba 7c
http://radiocontrolledshop.ie/futaba-pa ... st36-.html
Part Y MA8036. (probably same as 6ex) He can usually get the parts quite quickly. If you have no luck in the UK let me know and I will get one. I will order one myself soon anyway as I have a second 7c
Jan_Donadoni
Been liked: 6 times
Re: Futaba 7c
Thanks a lot to everyone!
Will update you soon
(George S. Patton)
John Davie
Been liked: 15 times
Re: Futaba 7c
Post by John Davie »
It's NOT the same as the 6EX, I have both and they are different part numbers. MA8036 is the 7c version.
John.
ARMORTEK: SdKfz 7, 88mm Flak36, 222, Sherman, Comet, T34, Firefly, Centurion, MarkIV, Limber, 25 Pdr, Pak 43, 17 Pdr.
Plus others!
