Spring Steel Supplier
Has liked: 1490 times
Been liked: 1697 times
Can anyone suggest a source of 10mm x 1mm spring steel, as used in parts CD0111 to CD0115 :?:
It would appear the Pz IV needs just over 6m, so I would guess 6.5m would cover cutting losses :?:
Is it usual to buy this sort of material as plain steel strip and heat treat it once cut to the correct dimensions :?:
Graham Ord
Has liked: 4 times
Been liked: 16 times
Post by Graham Ord »
I got mine from (with I think a minimum 10mtr order)
http://www.emmottsprings.co.uk/
Cut and drilled them, then had them heat treated by a local company who I knew very well.
Graham
Many thanks Graham.
I'll have a hunt in the Yellow Pages and see if there is anyone local who could heat treat them for me.
