Panther Cleaning Rod Canister and Hatch Bump Stops.
Mike Stannard (toyrific)
Hi Guys
With the introduction of my Bergepanther Set and will now have the Panther-Jagdpanther Cleaning Rod Cannister available for sale as a separate item, but on a very limited basis. The reason is, and why I sell the Panther and Jagdpanther as complete set only, these are photo-etched as complete sets. However the Bergepanther does not require the cleaning rod cannister. For every Bergepanther set I sell I will have one cleaning rod cannister available. Currently I have 3 Bergepanther sets on order, which means I have 3 cleaning rod canisters available.
These will be sold on a first come basis, once they are sold I can not offer them again until I sell a Bergepanther set. If you miss the boat on these 3 sets you can place a tentative order for them, but may have to wait a while for delivery.
I am offering the Cleaning rod canister in two sets, as assembled sets only.
6S-Pan08SA Panther and Jagdpanther C/Rod Canister and Pry Bar (Limited Availability) $150.00
This set is the basic canister with pry bar.
6S-Pan08SIA Panther and Jagdpanther C/Rod Canister, Pry Bar & Interior (Limited Availability) $240.00
This set will include the interior fittings to hold the spare antennas, SD antenna mast extensions and 5 piece cleaning rod. (Antennas and SD antenna mast extensions not included in set)
As the Hatch Bump Stops are only used on the Panther I have many sets available. These are sold assembled and ready to fix in place.
6S-Pan09SA Panther Driver and Radio Operated hatch Bump Stops Set of Two $20.00
Mike
