General radio (TX) question
Posted: Mon Apr 04, 2011 9:01 am
Hello,
I finally made it for my first trip out with my Tiger.
Many small issues, but easy to solve.
One problem.
VERY limited TX range. That is using the Hitec TX that came with the tank (both used) the max distance was 7-8 meters. Anyway BELOW 10 meters!
Maybe I have to reposition the antenna wire, or is it a common issue due to the heavy all metal construction?
By the way, I had NOT the same problem with the Jagdpanther, but the jagd is using a 2,4ghz Futaba radio and was running with both the top and rear plate temporary removed.
One problem.
