The new double torsion bar suspension has more than double the travel of the single bar set up.
Because of this the initial set angle is not so critical, and can vary from arm to arm by 20 degrees.
The optimum setting for the arms should be between 40 and 60 degrees.
Double Torsion Bar Suspension Settings
- Been liked: 3699 times
