Gear changes
- Has liked: 1479 times
- Been liked: 1683 times
Gear changes
As we're looking at the finer details, has anyone considered a way to imitate the changing of gears, with the associated lurch ?
I guess it should be possible to play Thomas's engine rev sound, to simulate a de-clutch, but the lurch is a little more difficult, especially with the ramps designed into the older speed controllers.
Great point Adrian.
The truck boys use a 3 speed gear box. See below.
A servo is used to shift gears which would give you the "jerk" especially if the throttle was dropped momentarily. The sound would have to match the gear change which might be a bit tricky. Also fitting in a 3 speed gear box in an already full hull might too be a problem too far.
Thanks Antony
Thanks Antony
- Been liked: 3 times
- Has liked: 2280 times
- Been liked: 7192 times
It's all to do with "dogs"
I try to simulate gear change but it is difficult.
Maybe Thomas could come up with a system to change gears (up and down the box) that uses say the throttle cut switch, I would be first in the line wanting one of those.
The Tiger1 and the Tiger2 that we are using at present both have reduction gearboxes and exstension spring suspension, the spring set up enables me to get that nice lurch on excelleration and decelleration with a good rock when firing the main gun, the wieght of the Armortek models gives us the inertia that looks so real .....when driven at a sencible speed!
The only way I can see to do it with the current setup (and I know Mark will curse me for saying this and probably wander off muttering about running gear stress and track link breakage) would be to put high power relays (or equivalent solid state device) in the feeds to the motors, such that the supply could be interrupted briefly. Heaven only knows what that would create in the way of back-EMF though.
- Been liked: 6 times
http://members.tele2.nl/s_weggeman/CG.htm
this is the final solution to the issue.
Designed also for big heavy metal tanks.
Maybe Armortek could develop next motion pack with this.
Also suited for gas-petrol engines, saw them working. Just take a look around on you tube.
Now that would be impressive
The website says suitable up to 30kg, so I guess it would need some strengthening to be usable with Armortek models.
I would guess that the clutches would be the parts most in need of increased capacity.
The strength goes with the material and the size you use.
On youtube you can find a UK modeler who build a 1/6 full metal Stug (3 or 4) with Cerjak Gearbox and a Honda 31 petrol engine.
The problem is with the sound of the motor, but otherwise it's really great and powerful. It also work 2 gears forward (high and low) plus back.
It also gives the tank a real BUMP when shifting from low to high gear.
Take a look at this series.
http://pktube.onepakistan.com/video/Pjg ... now-2.html
Also look after Mike Tull. He's the gentleman which built some CG for 1/6 metal tank models. Goolge Mike Tull petrol tank
I am just dreaming about an Armortek with a powerful electric motor (thus really silent) with a CG....
Actually, a change in motor technology may/would be a solution to all of this; but, its a big leap that would take a major electronics refit and redesign.
What I am talking about is the use of stepper motors and an associated, computer-based speed controller.
I saw a demo of a line-shuttle robot some years back that used this sty;e setup = it was quited, very powerful, and could be controlled to simulate speed shifts (they did it in the demo as a lark). I know that steppers allow for precision "jog" control; so, it could also give you the "rocker" action you may want for the simulated main-gun fire control as well.
Well, its a suggestion,
Jim
Jim
Thanks,
Jim
Jim
I believe it would not be so difficult.
Instead of two separate motors we would have only one, we would have 1 additional servo (high torque)for the gear shift and finally would need some space in the front of the tank to place the gearbox.
Actually already someone is using such system.
Most of all, from a technical point of view, it is the nearest thing to real tank transmission, as much as I know.
An electric-motor driven gearbox would also hopefully allow for the tank to be put into neutral and hence it would be possible to push them around when the battery is low.
I must admit I'd want properly cut gears in the gearbox though, the ones I have seen running are quite noisy in themselves, though I guess flooding them in oil might alleviate that to some degree.
I wonder what Ncm strength servo motors would be equivalent to the current EMD motors ?
- Been liked: 25 times
I have build gearboxes for all my models and it makes a lot of fun to drive such a model.
I have started in scale 1/10 with 3 gears and overlapsteering with differentials.
In the 1/6 Panther gearbox I have changed the differentials into planetary drives, because they are stronger. I only need one drive motor and a smaller steeringmotor. In the first gear the max. speed is about 2,5 km/h and in the third gear the tank is about 8km/h fast and I think that`s enough.
The weight from the Panther is 140kg and I can shift during driving, the tank doesn`t stop when I put the next gear in.
Bodo
Bodo
- Been liked: 2 times
