Fixing the rear deck
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
I order to fix the rear deck down without using the 6 screws I have fiited a bracket to one of the stretcher bars and threaded the spacer for the vent. I can get at the wing nut to fix it by opening the 2 rear hatches and it hold it really firmly. Means I can fill the 6 screw holes now.
phil fitzpatrick
Been liked: 223 times
Rear Deck fastener
Post by phil fitzpatrick »
Hi Dennis
That was a clever idea for your deck fixing and I like your flasher ithe dark vidio.
Look forward to seeing it in your gun.
David Skeldon
Has liked: 33 times
Been liked: 312 times
Post by David Skeldon »
Hi,
Mine runs without the rear deck bolted down.The weight alone is enough to keep it inplace.
Dennis Jones
Has liked: 10 times
Hi David,
I was thinking not to bother with fixing it but I have had the turret on the Panzer nearly fall off after a rough traverse of some logs so it was a bit of belt and braces I guess and I couldn't be doing with undoing 6 screws and also the look of it as well.
