TRACKS
- Has liked: 4 times
- Been liked: 16 times
TRACKS
On the plans for the Panzer IV the track pins are shown knurled on one end to hold them in the track links. How were the track pins held in place ( both inner and outer ends ) on the real thing? I have looked at several photo,s which show some kind of pin (split?).
Graham
- Has liked: 116 times
- Been liked: 1106 times
Hi Graham,
split pin through the end of the track pin, not a great picture as they are badly corroded and can't find my others but it should give an idea,
Dave
Dave
www.armorpax.net
- Been liked: 10 times
Graham,
The split pin system will work well on the model, RS do a 1.2mm diameter split pin that will be ideal. On the early Tiger models Armortek used the sprin washer system, but lots of us had problems with these coming off. You may find that knurling and pressing the pins in will be ok but with the cast track links the push fit may be compromised if you have to drive a pin out and re-fit it.
Allan Richards
TRACKS
Thanks for the replies, seems like its got to be split pin and washer on bothe inner and outer ends of the track pins.
Graham
TRACKS
As a matter of interest what is "STEEL EN1PB" the actual specification for the track link pins on the Panzer IV drawings. A search of the WEB produces nothing usefull.
Graham
- Been liked: 54 times
- Been liked: 3713 times
Steel EN1 pb
Graham
This is lead bearing mild steel. The addition of a very small amount of lead in the steel makes it much more freely machinable. It is the grade we use for all turned steel parts and is readily available from all bright steel stockholders.
