This is what I came up with to solve the issue I was having with my road wheel clearance. I change the hardware on the outside wheels from the cap head screws that were provided; to button head screw the same length.
The other question I was having was the alignment of the road wheels to the idler and the drive sprocket; this was off a little. I purchased some 10 x 16 x .05 mm shims for the axle shafts and 10 x 5 x .05 mm shims for the axle ends. I tried a few different arrangements and found that 2 shims worked the best, putting the alignment dead on from the front to the back. It also added a millimeter to the clearance of the road wheels.
My plans now are to take everything apart and paint the base coat on the hull bottom, arms and road wheels: then re-assemble for the final time.
