Tiger Build Pics.
David Ward
Tiger Build Pics.
Post by David Ward »
Some new pics in my gallery. (Page 7)
David,
Outstanding! Your Tiger is looking really nice. Super zimmerit job.
Thanks for posting the pictures of your progress as it's great inspiration for my Tiger when I get it.
Keep up the great work and I look forward to seeing more.
Dale jordan
Been liked: 514 times
Post by Dale jordan »
Hello David . I didnt even know you had a late tiger . After seeing your photos you have been very busy . She looks great . It's Interesting to see all the studs on the wheel hubs. There must be one more set of wheel to go on ?? . One thing you need to do David is to change around the bolts on the exhaust armored guards the nuts go on the out side . It looks like the late tiger has more detailed parts e.g , bump stops and track pin deflectors on the lower hull plus lots more . Dale.
David Ward
Dale / Tim
Thank you for the comments.
Dale - My nuts will soon be on the outside.
Tim - The Zimmerite is one of those builders adhiesive / gap fillers in a tube called Grip Fix. It is a solvent based one, so it starts to set fairly quickly and so you have to do a small area at a time. It also works out cheap, one tube should do the whole tank.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi David
Good looking Tiger. I have used Grip fill as the welds on my Panther and
the results are very good too.
A freind of mine is a welder and asked who had done the
welding of my hull ! So it must be ok. :lol:
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Dave,
Interesting choice of material to do the zimmerite. I've used it as a jointing glue to support the hull joints on the Sherman and it certainly sticks well and adds a lot of strength, probably better than milliput, and its a lot cheaper. Did you sperad and work it with wet tools?
Allan Richards
David Ward
Allan
First I applied it all over the area with the squirty gun thing. Than immediatly spread it by thumb (messy). After a couple of minuets when the surface is starting to dry I rolled it with a bit of 1 inch brass tube - keeping it clean, (just a bit I had available, any thing metalic and round of a suitable size would do) just to even it out and than applied the pattern with a chisel, and yes did wet the chisel and roller as it does help to stop it sticking. The whole hull didnt take more than 3-4 hours once the technique was perfected, and all for less than a fiver. I found doing about 4 inches at a time was about right before it starts to set to much.
