Hi guys,
I am trying to help Norbert Poland with his KT electronics.
He is using a Futaba T10CG 2.4G radioset and wants to control both motors on a single stick. I have gone through the earlier postings on this matter, but unfortunately these are of no use on the a.m. radio.
An elevon/ V-tail mixing is only applicable to channels 2 and 4, i.e. on 2 sticks. Has anyone tried an alternative solution e.g. with a DMR 203 interface or a standard V-tail mixer ?
Any suggestions are most welcome.
Single stick control
- Been liked: 2 times
- Mick Regan
- Has liked: 34 times
- Been liked: 6 times
Hi Ad
If you are using a DMR 203 with 4QD controllers, remove the steer mode jumper and connect the channels from the stick you want to drive on, and thats it. See page 4 of the manual to show you the jumper positions. The default position which the units are shipped is in "tank mode", i.e. 2 stick steering.
Hope this helps
Mick
Hope this helps
Mick
