Sound System Benidini
- Been liked: 15 times
Hello Chaps
Does any one who uses a benidini sound system use different way of switching it on, not via the joy stick.ie key fob etc.I want to do that to my Panther.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Mick Regan
- Has liked: 34 times
- Been liked: 6 times
Hi Lee
I use the Quasar 10 system from Hunter Systems at http://www.huntersystems.co.uk/acatalog ... ntrol.html
It's a UHF system, which is independent of your transmitter. It has 4 buttons which control 10 different funtions using different combinations of buttons. I have mounted mine inside my transmitter with 4 buttons on the front panel.
Main problems I've come across are :
1/ Range is not as far as main radio control system.
2/ Requires a 12 voly supply. I use a seperate battery mounted between the drive motors to power it and my Benedini sonud system and amp.
A possibly better solution I have seen used is a 8 way switch unit which uses a spare channel on your transmitter, so there is no reduction in range. have a look at http://www.pandanmodelboats.co.uk/acata ... s_235.html This is a future project for me, so if yiou are happy to wait, I'll let you know what I think.
Hope this helps
Mick
Hope this helps
Mick
Hello Mike
Thanks for that i will give it ago.
Lee
Lee
- Has liked: 218 times
- Been liked: 181 times
- Been liked: 9 times
- Mick Regan
Hi Colin
Sounds like a good idea. The 8 way switch unit from Pandan Models is currently out of stock, and I'm waiting for a reply to an email I sent them.
When I get my hands on one, I'll give it a go. If it's anything like the Hunter Systems 10 channel switch unit, there's some soldering and a lot of extra wiring involved.
I'll keep you posted on any developments.
Mick
Mick
- Mick Regan
Hi Colin
The easiest way of getting away from the stick method of sound activation is to buy Benedinis 12 posoition rotary switch encoder.It needs just 2 holes drilled in the transmitter case for a rotary switch and a push button switch. You select the sound you want with the rotary switch and push the button to activate it. It plugs into 1 of the proportional channels. It means you loose the use of one of the control sticks unless you're lucky enough to have more than 4 proportional channels.
The loss of a channel was the main reason for using the Hunter UHF system, but it has its limitations, so I'm investigating other options.
I think the prefered option for most people would be to push1 button for 1 sound, not twiddling sticks, or trying to push multiple button combinations.
This post has made me put my thinking head on. Haven't done that for a while. Hurts a bit when I think to hard I'll have to mull this over a pint of beer.
I'll keep you posted on my ramblings
Mick
P.S. If anybody already has a Benedini rotary encoder could they send me a PM. Cheers
Mick
- Mick Regan
Hi Colin
What burnt out? If it was the sound board, it can be reprogrammed to the rotary setector mode. It's explained in the instructions under "Parameter settings:" pages 12 & 13.
Mick
Mick
Hi guys.
A friend of mine has a Benedini encoder fitted to his Futaba 6exap 40mhz.
This is wired up to channel 6 which has a proportional flaps knob on it.
Now down to the tricky bit.Does any one have any idea how to do this on a 6exa 2.4 ghz that has a two position switch for channel 6.
On a quick look inside, both of these radio's they look almost the same.
This is where my electronics knowledge runs out.
Many thanks
Marc
Many thanks
Marc
Vere did all zose shermans come from ?
- Has liked: 1384 times
- Been liked: 1580 times
I've tried adding the pot from a 40MHz 6exap to a 2.4GHz 6ex but that channel is programmed to only generate a high/low signal, so it makes no difference whether there is a switch or a pot attached.
Until Futaba see that changing this pot for a switch was a retrograde step, I'm afraid this channel is pretty much useless.
- Has liked: 257 times
- Been liked: 187 times
- Mick Regan
Hi Stuart
I have pictures of the instillation with a short narrative which I can email you if you're interested
Mick
Mick
